山东瑞鑫金属材料有限公司
Shandong xin metal materials co., LTD
主营:铝管,铝棒,铝板,铝排,方管,方棒,六角棒,铝型材
Shandong xin metal materials co. LTD
发布日期:2016-10-15 来源:网络 作者:瑞鑫
Long-term production and sales of aluminum alloy tube seamless aluminum tube thick-walled aluminum tube aluminum aluminum tube aluminum bar aluminum and other aluminum profiles. The products are sold to the implementation of national standards for engineering, coal, textiles, electric power, boilers, machinery, military, aviation, automobile industry, shipbuilding and other fields. In this case,
    Main materials are: 6063 (t5, t6) 6061 (t4, t5, t6) 2024 (LY12 2A12) 3A21 (rust-proof hard aluminum) 6005 7075 【t5 T6】 5052 【5056 5083】 1060 【1050 1100 pure aluminum】
    Thickness: 4mm-506mm Thickness: 0.7mm-50mm (Material: 6063 6061 6005) Welding performance is good, the hardness is general, the most widely used.
    Seamless aluminum tube specifications Diameter 8mm-260mm wall thickness 1mm-25mm (all materials for the 2024 domestic also known as the LY12 or 2A12 hardness ultra-high production process for the super-hard aluminum rod perforation)
    Rust-proof aluminum tube diameter 10mm-300mm thickness 1mm-30mm (5 Department of aluminum pipe seam, anti-corrosion ability, most used for ships, cruise ships, motorboats)
    7075 aluminum tube spot diameter 16mm-185mm wall thickness 2mm-16mm (7075 material aluminum tube for the majority of aircraft use, the characteristics of low density, low density, hardness higher than the ordinary alloy aluminum tube 1.5-2 times! But its price than the same specifications Aluminum tube high close to 120%, so the price determines the 7075 most of the aluminum tubes used in the more expensive, advanced, sophisticated equipment above)
    Aluminum square tube size 10 × 10 × 1 20 × 20 × 30 × 30 × 3 and so on until the 100 × 100 × 10 are available from stock, the other specifications of the aluminum tube spot Please refer to the product specifications in the aluminum side of the table.
产品供应
